TOM VITAZ
#1 Posted : Wednesday, October 19, 2011 3:11:54 PM(UTC)
TOM VITAZ
Groups:: Registered
The Belt On The Washer Came Off Of The Pulleys,upon Dealing With The Belt To Drive Pulley Seems Really Sloppy Or Lose, The Nut Was Not Lo In Boose But The Pulley Has A Lot Of Play In It In Either Direction Is Nthat Normal, The Belt Did Not Break
sidfink43
#2 Posted : Friday, October 21, 2011 5:30:26 PM(UTC)
sidfink43
The pulley should not have a lot of play. It is held on by a 21mm nut. But it sounds like the basket may be loose, check out the support struts and springs.
Tight drive pulley after bearing replacement (Washer Repair)
by maverick 5/24/2017 9:48:04 AM(UTC)
Replacing the drive pulley on a Duet Dryer (Dryer Repair)
by rkeranen 7/14/2015 6:02:55 AM(UTC)
GE drive pulley grinding (Washer Repair)
by Nick Good 12/7/2014 8:11:02 PM(UTC)
Replacement Drive Pulley for Maytag Performa (Dryer Repair)
by dsuper11 9/8/2012 9:01:54 PM(UTC)
kenmore dryer drive pulley (Dryer Repair)
by nsoron2@att.net 4/28/2012 6:18:48 AM(UTC)
change drive belt and drive pulley (Washer Repair)
by clacker48 3/8/2010 8:27:42 AM(UTC)
by acuevas 6/2/2009 4:59:00 PM(UTC)
drive pulley falls off (Washer Repair)
by daddd 2/1/2008 5:43:03 PM(UTC)
