tward
#1 Posted : Wednesday, December 5, 2007 11:53:42 AM(UTC)
tward
du1055f lite is blinking and will not start. I check heating ele. should read 10 to 30 ohms it shows 9 ohms.fuse is good,temp switch is good.Need help
#2 Posted : Wednesday, December 5, 2007 12:20:02 PM(UTC)
What light is blinking? Clean?
Did you check the hi limit thermostat?
tward
#3 Posted : Wednesday, December 5, 2007 12:32:15 PM(UTC)
tward
Hi, I check one thermostat on the bottom of the tub it was closed.
#4 Posted : Wednesday, December 5, 2007 12:53:27 PM(UTC)
You can find the full description on this problem and how to fix it in the Whirlpool service pointer and technical data sheet.
tward
#5 Posted : Wednesday, December 5, 2007 12:58:44 PM(UTC)
tward
Thanks,I will reistall the washer and try it agin.
Whirlpool Dishwasher buttons don’t do anything (Dishwasher Repair)
by Blobula 6/13/2018 7:25:28 PM(UTC)
Whirlpool Dishwasher is buzzing and will not fill with water (Dishwasher Repair)
by christyhecht 5/15/2018 9:05:36 PM(UTC)
Whirlpool Dishwasher has no power and there is water in bottom (Dishwasher Repair)
by Tracies12 1/27/2018 10:20:44 AM(UTC)
Whirlpool dishwasher Dishes wet and dirty (Dishwasher Repair)
by TysonHorlacher@gmail.com 12/19/2017 11:55:47 AM(UTC)
Whirlpool dishwasher will not run (GU1500XTLS2) (Dishwasher Repair)
by mindnmines 3/3/2017 4:47:18 AM(UTC)
Whirlpool Dishwasher Fills But Doesn't Wash Then Drains (Dishwasher Repair)
by DSGDSG 1/27/2017 10:35:12 AM(UTC)
Whirlpool Dishwasher begins wash cycle, fills and then stops (Dishwasher Repair)
by tinfootoo 11/1/2016 2:34:31 PM(UTC)
Whirlpool dishwasher won't heat (Dishwasher Repair)
by bremja 6/21/2016 7:00:10 AM(UTC)
whirlpool dishwasher leaking from door (Dishwasher Repair)
by pburd89 2/19/2016 1:36:17 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Whirlpool dishwasher - circulation pump? (Dishwasher Repair)
by Downtown 12/1/2015 4:08:35 PM(UTC)
Whirlpool Dishwasher Not Working (Dishwasher Repair)
by krupp72001 11/8/2015 2:46:14 PM(UTC)
Whirlpool Dishwasher Control Panel Lights All On (Dishwasher Repair)
by DaHadster 9/12/2015 12:01:22 PM(UTC)
Whirlpool dishwasher won't rinse (Dishwasher Repair)
by Stressed Mom 9/10/2015 12:31:54 PM(UTC)
Whirlpool Dishwasher drain water issue (Dishwasher Repair)
by yyzt4e 8/4/2015 6:23:01 AM(UTC)
