Hello -
I pulled out the cover, screen, filter basket, diffuser and spray arm and run the dishwasher - no leak.
If I put the diffuser and cover back in it leaks on the underside of the unit in the center.
Is it the diffuser motor or the sump that I need to replace?
Thanks!
