tward
#1 Posted : Wednesday, December 5, 2007 11:53:42 AM(UTC)
tward
du1055f lite is blinking and will not start. I check heating ele. should read 10 to 30 ohms it shows 9 ohms.fuse is good,temp switch is good.Need help
#2 Posted : Wednesday, December 5, 2007 12:20:02 PM(UTC)
Views messages in topic : 27,455
What light is blinking? Clean?
Did you check the hi limit thermostat?
tward
#3 Posted : Wednesday, December 5, 2007 12:32:15 PM(UTC)
tward
Hi, I check one thermostat on the bottom of the tub it was closed.
#4 Posted : Wednesday, December 5, 2007 12:53:27 PM(UTC)
You can find the full description on this problem and how to fix it in the Whirlpool service pointer and technical data sheet.
tward
#5 Posted : Wednesday, December 5, 2007 12:58:44 PM(UTC)
tward
Thanks,I will reistall the washer and try it agin.
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
