ZDM
#1 Posted : Sunday, October 16, 2011 8:53:11 AM(UTC)
ZDM
Hello,
I have a Whirlpool Accubake Gold oven. While in the cleaning mode, the oven door locking mechanmism clicks on and off loudly. Won't stop.
Thoughts
cz85b
#2 Posted : Tuesday, January 3, 2012 8:58:48 AM(UTC)
cz85b
Originally Posted by: ZDM Go to Quoted Post
Hello,
Thoughts
I have the same issue.. I am looking into contacting Whirlpool with the problem, but any help from the forum would be most welcome!
#3 Posted : Tuesday, January 3, 2012 12:51:34 PM(UTC)
What is the complete model number of the oven?
cz85b
#4 Posted : Wednesday, January 4, 2012 10:24:34 AM(UTC)
cz85b
Model # GR450LXHQ 2
S/N
IML4849745
30p
It would be very cool if you could point me in the right direction!
Steve
#5 Posted : Wednesday, January 4, 2012 12:18:59 PM(UTC)
Hi Steve,
Pull the range out of the wall. Remove the rear cover and check the door latch switches and solenoid (#26 & #27 on the diagram). check the wires from the door latch to the control board.
If there is nothing wrong, replace the control board. If you need the correct part number for the control board, post the color of the keypad.
- The door latch solenoid Part number: AP3007999
cz85b
#6 Posted : Wednesday, January 4, 2012 12:33:09 PM(UTC)
cz85b
I will check the above and if they are good, I will respond with the color of the keypad..
Thank You Doctor!
Steve
