Hello,
I have a Whirlpool Accubake Gold oven. While in the cleaning mode, the oven door locking mechanmism clicks on and off loudly. Won't stop. Thoughts
Originally Posted by: ZDM  Hello,
I have a Whirlpool Accubake Gold oven. While in the cleaning mode, the oven door locking mechanmism clicks on and off loudly. Won't stop. Thoughts I have the same issue.. I am looking into contacting Whirlpool with the problem, but any help from the forum would be most welcome!
What is the complete model number of the oven?
Originally Posted by: Gene  What is the complete model number of the oven?
Gene. Model # GR450LXHQ 2 S/N IML4849745 30p It would be very cool if you could point me in the right direction! Steve
Hi Steve, Pull the range out of the wall. Remove the rear cover and check the door latch switches and solenoid (#26 & #27 on the diagram). check the wires from the door latch to the control board. If there is nothing wrong, replace the control board. If you need the correct part number for the control board, post the color of the keypad. - The door latch solenoid Part number: AP3007999
I will check the above and if they are good, I will respond with the color of the keypad..
Thank You Doctor!
Steve
