varsboyd
#1 Posted : Thursday, April 30, 2009 7:50:31 PM(UTC)
varsboyd
When I set the water level to "ex high" and wash a load of clothes washer leaks. Does not leak when water level is set to "ex low" or "med". Do you think that it is the Tub Ring Seal?
#2 Posted : Friday, May 1, 2009 2:40:47 AM(UTC)
Need model # to help.
varsboyd
#3 Posted : Friday, May 1, 2009 8:04:49 AM(UTC)
varsboyd
Sorry about that. The model number is: 110.82372120.
#4 Posted : Friday, May 1, 2009 8:42:45 AM(UTC)
You have the old type washer. Yank the top up and look at the bottom of the tub, if you see water coming out, you probably have a bad tub seal or a rusted out tub. Probably not worth fixing, will have to remove the tub to put new seal in and you may find rust holes in the steel tub.
varsboyd
#5 Posted : Friday, May 1, 2009 1:42:15 PM(UTC)
varsboyd
Thanks. Since water only leaks out when I set the water level to "ex high" and wash a load of clothes wouldn't that lead you to believe that the tub ring seal that fits on top of the basket and tub is leaking as oppose to the tub being rusted out? Thanks for your time.
#6 Posted : Friday, May 1, 2009 3:17:34 PM(UTC)
Small tub leaks will get bigger and more noticeable due to the increased water pressure. Sometimes, if the snubber is worn, and it shakes in spin, it could splash out over the rim of the tub.
Washer leaks at end of cycle only (Washer Repair)
by Orvilejulius 8/13/2023 8:42:38 PM(UTC)
Dishwasher leaks after inlet valve (Dishwasher Repair)
by amazingAZ 6/2/2022 8:57:54 PM(UTC)
Washer leaks water only when using water outside (Washer Repair)
by MattWasPele 9/21/2020 9:46:26 AM(UTC)
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 8/1/2020 8:44:37 AM(UTC)
GE Washer leaks after sitting? (Washer Repair)
by redjada 4/11/2018 2:46:00 PM(UTC)
Washer leaks on front door (Washer Repair)
by robertkral1 10/4/2017 11:41:47 AM(UTC)
Washer leaks and fills drain tray (Washer Repair)
by boberp 3/13/2016 7:27:42 AM(UTC)
Kitchenaid Dishwasher Leaks at Float (Dishwasher Repair)
by macd2x 11/8/2015 7:29:26 AM(UTC)
Washer leaks (Washer Repair)
by DIYChallenged 9/14/2015 10:15:27 AM(UTC)
Dishwasher leaks front door (Dishwasher Repair)
by kbratto 8/26/2015 9:53:11 AM(UTC)
New Maytag top load Washer Leaks in Front (Washer Repair)
by Gadgetmonster 7/10/2015 9:11:53 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Kenmore portable washer leaks (Washer Repair)
by Jimisand 3/9/2015 10:38:25 AM(UTC)
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Washer Leaks while filling up .. Large Loads Only (Washer Repair)
by martynva 7/26/2014 3:17:06 AM(UTC)
