micheleck
#1 Posted : Monday, April 27, 2009 3:13:47 PM(UTC)
micheleck
I am having a problem with my washer...at the end of the cycle my clothes are still sopping wet...the washer is spinning but at a much slower than normal speed...it seems if I put in a medium load and then re-spin at the small load setting, sometimes it will spin out...and sometimes it doesn't..any suggestions?
applianceman
#2 Posted : Monday, April 27, 2009 5:25:07 PM(UTC)
applianceman
The first things to look at are the belts. If the belts are slipping they will cause the washer to spin slow. They could just be worn out and replacing both of them will do the trick. At times the washer will leak grease onto the belt causing it to slip in which case you need to repair the grease leak or it will do it again. Other times water will leak in the belt causing the same thing and you will need to repair the leak as well. Check it and post you findings. Hope this helps! Clothes Washer Repair Guide
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
