I am having a problem with my washer...at the end of the cycle my clothes are still sopping wet...the washer is spinning but at a much slower than normal speed...it seems if I put in a medium load and then re-spin at the small load setting, sometimes it will spin out...and sometimes it doesn't..any suggestions?
The first things to look at are the belts. If the belts are slipping they will cause the washer to spin slow. They could just be worn out and replacing both of them will do the trick. At times the washer will leak grease onto the belt causing it to slip in which case you need to repair the grease leak or it will do it again. Other times water will leak in the belt causing the same thing and you will need to repair the leak as well. Check it and post you findings. Hope this helps! Clothes Washer Repair Guide
