tzurita
#1 Posted : Monday, April 27, 2009 1:52:13 PM(UTC)
tzurita
Tried to change out broiler element. Installed new element, only hooked up red wire (did not knkow ther was a blue one) Turned breaker on and I think it blew. Now Control panel will not come on.
#2 Posted : Monday, April 27, 2009 4:12:21 PM(UTC)
Here are the parts
Replacement parts for AMANA AES1350BAW | AppliancePartsPros.com
Here is a service manual and tech sheet
http://www.servicematters.com/m...ibrary/docs/16026299.pdf
http://www.servicematters.com/m...ibrary/docs/16026294.pdf
I assume you have hooked the element up properly now.
Check the power at the plug
Should be 240 volts L1 to L2
Should be 120 volts L1 to Neutral and L2 to Neutral
Be sure to unplug the unit when working on it, 240 volts is lethal.
Could be the control board is blown!!
kayakcrzy
#3 Posted : Tuesday, April 28, 2009 5:10:39 AM(UTC)
kayakcrzy
Originally Posted by: tzurita Go to Quoted Post
tried to change out broiler element. installed new element, only hooked up red wire (did not knkow ther was a blue one) turned breaker on and i think it blew. now control panel will not come on.
look at # 6 on the body breakdown of your oven. i would cut the power off, and take the 2 wires off of it, and put a little tape around it, so it does not hit metal,and jump it out, and see if the clock comes back on. if it does, replace it, and do not use the oven with the limit switch jumped out. it is a saftey. tom www.applianceeducator.com/parts.htm:cool:
Electric Broiler element meltdown (Oven Repair (including Ranges and Cooktops))
by lilsad 7/24/2022 9:59:00 AM(UTC)
Using a Broiler element to replace a bad Bake Element (Oven Repair (including Ranges and Cooktops))
by Guest 11/22/2021 2:49:19 PM(UTC)
Unable to replace broiler element support (Oven Repair (including Ranges and Cooktops))
by jenniferverde 3/10/2018 4:42:50 PM(UTC)
broiler element remains warm when oven is off (Oven Repair (including Ranges and Cooktops))
by B. Edwin 12/18/2017 12:17:01 PM(UTC)
Troubleshooting A Broiler Element (Oven Repair (including Ranges and Cooktops))
by mlochala 9/5/2017 4:28:16 PM(UTC)
Electric Wall Oven broiler element stays on (Oven Repair (including Ranges and Cooktops))
by magicman1963 12/26/2016 6:29:18 PM(UTC)
replaced broiler element, still not working, next step? (Oven Repair (including Ranges and Cooktops))
by candititans@yahoo.com 10/20/2016 12:47:29 PM(UTC)
Frigidaire wall oven broiler element not working (Oven Repair (including Ranges and Cooktops))
by rpdandy 9/11/2016 3:24:37 PM(UTC)
Broiler Element Not Working (Oven Repair (including Ranges and Cooktops))
by George_H 2/21/2016 11:50:14 AM(UTC)
Baking element not working but broiler element is working (Oven Repair (including Ranges and Cooktops))
by majeromero 9/15/2015 7:41:26 PM(UTC)
Broiler element always on (Oven Repair (including Ranges and Cooktops))
by Rob D 7/11/2015 6:39:55 PM(UTC)
Broiler Element stays on all the time (Refrigerator & Freezer Repair)
by herminio1969 5/20/2015 6:19:39 AM(UTC)
Running Without Broiler Element (Oven Repair (including Ranges and Cooktops))
by jgpa 5/1/2015 7:47:23 AM(UTC)
Electric Range not heating bake or broiler elements (Oven Repair (including Ranges and Cooktops))
by ndh_mashfan 12/21/2014 3:50:07 AM(UTC)
Top oven only broiler element working (Oven Repair (including Ranges and Cooktops))
by DKil 10/15/2014 5:56:10 PM(UTC)
