Drum fills with water, agitator won't turn on the wash or spin cycle, water drains. slight odor when agitator is supposed to be moving; grinding noise, no squealing noise. pile of black dust-like residue on floor under washing machine.
Most likely the problem with your washer is a worn out motor drive coupling (#13 on the break down diagram). - The part number for the motor drive coupling AP3963893 - Here are the break down diagrams for the Roper washer Model RAS8245EW0Gene.
