The pots and pans light blinks non stop I called parts pros and they sold me a electonic board WPL 8530929 I changed it and same problem. I called parts pro back they sent me another board, I changed it and once I pressed the hot wash and pots and pans button serveral times it started to work; it went through a complete cycle but then after a day it went back to just the pots and pans light blinking again. I press the hot wash and pots and pans button several times it then starts but runs for about 30 seconds and then stops and the pots and pan button begins to flash again.
gddsgfesdgsadhs Originally Posted by: Maytag man  The pots and pans light blinks non stop I called parts pros and they sold me a electonic board Whirlpool 8530929 I changed it and same problem. I called parts pro back they sent me another board, I changed it and once I pressed the hot wash and pots and pans button serveral times it started to work; it went through a complete cycle but then after a day it went back to just the pots and pans light blinking again. I press the hot wash and pots and pans button several times it then starts but runs for about 30 seconds and then stops and the pots and pan button begins to flash again.
