Good morning, I would like to know how to put the belt on the dryer, and what do I have to take apart to put the belt on.:)
You will need to remove the 2 screws by the lint screen, use a putty knife to release the clips between the top panel and the front. Raise the top, much like a car hood. Then reach in and unplug the door switch pick up on the front panel slightly and remove. You can them install the new belt around the drum and pulleys and reverse the process.
Nat
