Just used the self cleaning operation on stove and now error message on display panel comes up F1-1. I have already let oven cool down and reset breaker to oven. Code still comes up stating call a Maytag Technician. What is the most likely source of this problem and solution?
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
My mom has a range which she purchased 6/23/08 and the model # is FEF402DWF recently (3 times) the display will beep and the info comes up F-10??? what does this mean?
ldavis Could not find any info using the given Model Number, please check it. Is it a US unit? I did find a Maytag F1-1 error code but it was for a dual oven unit. Pointed towards the upper oven's temperature sensor being bad. Here is a good link http://www.applianceaid.com/elecrange.html Check out # 7 and 8 Most F1's for Maytag ovens point to a bad keypad. RIBBON CABLE CLEANING Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. Also check the ribbon cable tracks for cracks a magnifying glass helps here Janice Brock Please start your own thread in the Oven Repair section using Post New Topic. You are just confusing things by being on this thread. You have a different problem and a different machine so any answer to ldavis will not apply to you. |
THIS FORUM IS DEAD!!!!!!! |
