ldavis
#1 Posted : Wednesday, April 22, 2009 6:35:05 AM(UTC)
ldavis
Just used the self cleaning operation on stove and now error message on display panel comes up F1-1. I have already let oven cool down and reset breaker to oven. Code still comes up stating call a Maytag Technician. What is the most likely source of this problem and solution?
ldavis
#2 Posted : Wednesday, April 22, 2009 6:37:10 AM(UTC)
ldavis
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Janice Brock
#3 Posted : Thursday, April 23, 2009 8:26:34 AM(UTC)
Janice Brock
My mom has a range which she purchased 6/23/08 and the model # is FEF402DWF recently (3 times) the display will beep and the info comes up F-10??? what does this mean?
#4 Posted : Friday, April 24, 2009 2:05:44 AM(UTC)
ldavis
Could not find any info using the given Model Number, please check it.
Is it a US unit?
I did find a Maytag F1-1 error code but it was for a dual oven unit.
Pointed towards the upper oven's temperature sensor being bad.
Here is a good link
http://www.applianceaid.com/elecrange.html
Check out # 7 and 8
Most F1's for Maytag ovens point to a bad keypad.
RIBBON CABLE CLEANING
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Also check the ribbon cable tracks for cracks a magnifying glass helps here
Janice Brock
Please start your own thread in the Oven Repair section using Post New Topic.
You are just confusing things by being on this thread.
You have a different problem and a different machine so any answer to ldavis will not apply to you.
kayakcrzy
#5 Posted : Friday, April 24, 2009 4:36:52 AM(UTC)
kayakcrzy
Actually on the F1 error code it states touch pad or ERC. Tom ApplianceEducator.com
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
EA120 EA150 Bosch Error Code - Built In Refrigerator (Refrigerator & Freezer Repair)
by Peter Franks 2/13/2024 4:55:41 PM(UTC)
Samsung Error Code (Oven Repair (including Ranges and Cooktops))
by Guest 11/6/2023 12:46:38 PM(UTC)
Kenmore OL Error Code (Washer Repair)
by Guest 10/27/2023 8:37:16 PM(UTC)
KitcheAid Microwave/Oven Wall Combo KOCE500ESS05 Error Code F6E8 (Microwave Repair)
by tjperlman 10/19/2023 10:07:59 PM(UTC)
Kenmore Elite F09 error code (Washer Repair)
by dieselgg 10/19/2023 4:01:12 PM(UTC)
F2 Error Code on GE Electric Oven (Oven Repair (including Ranges and Cooktops))
by Guest 9/11/2023 6:33:44 PM(UTC)
Error code SY EF (Refrigerator & Freezer Repair)
by Guest 7/17/2023 1:05:46 PM(UTC)
LG Dryer DLGY1702VE no error codes (Dryer Repair)
by Lisssasue 7/17/2023 10:41:37 AM(UTC)
KitchenAid Error Code 6-1 (Dishwasher Repair)
by JBishop 4/7/2023 12:37:12 PM(UTC)
Kenmore Elite Washer error codes (Washer Repair)
by Cenzo 3/23/2023 12:58:19 PM(UTC)
Kenmore washer error codes (Washer Repair)
by Guest 3/5/2023 7:00:21 AM(UTC)
GE Refrigerator diagnostic mode error codes (Refrigerator & Freezer Repair)
by Guest 1/22/2023 10:11:53 AM(UTC)
Kennmore Elite Top Load Washer - MHK62125813 - Error Codes (Washer Repair)
by maxxam864 1/4/2023 12:11:00 PM(UTC)
Control board for Frigidaire Affinity dryer (E68 error code) (Appliance Parts)
by VanFramez 12/18/2022 11:57:30 AM(UTC)
