zeke7237
#1 Posted : Friday, September 23, 2011 3:29:06 AM(UTC)
zeke7237
4 year old Amana, all electronic defrost so should be easy to figure out ..
Everything is fine as far as I know, then Irene comes and we're running on generator for a week starting and stopping. A week after hurricane we experience hot fridge cold freezer and discover iced up condenser.
Defrosted manually, put back together and watched for a couple weeks .. and it iced up again. Defrosted again and proceeded to troubleshooting.
Control panel test shows safety thermostat is OK, element heats .. verified with ohmmeter as well. So the board can read thermostat, and turn on element .. what the heck else can be wrong here?
#2 Posted : Sunday, September 25, 2011 1:20:08 AM(UTC)
I cannot find any info at AppliancePartsPros or Amana.
Please check it.
They probably have parts for this unit but it is too new to come up on the system.
If I understand your post you can force a defrost cycle and it does work.
This shows that the defrost heater and the defrost thermostat are OK.
So whatever is programming the defrost cycle is not advancing to program the cycle. Could be a defrost timer, an adaptive defrost board or the main control board.
I would have to find some tech info to tell which this unit uses.
MayTag defrost issues ????? (Refrigerator & Freezer Repair)
by HHM1435 10/16/2017 1:03:48 PM(UTC)
GE Defrost Issues (Refrigerator & Freezer Repair)
by WVU 9/23/2014 7:40:11 AM(UTC)
defrost issues (Refrigerator & Freezer Repair)
by jbain7005 10/16/2013 3:44:10 AM(UTC)
Freezer Defrost Issues (Refrigerator & Freezer Repair)
by smuth10 5/9/2013 5:10:31 AM(UTC)
Freezer with defrost issues - dripping water inside. (Refrigerator & Freezer Repair)
by mbockus 8/22/2011 7:43:05 PM(UTC)
by Dennis3816 5/20/2011 10:33:38 AM(UTC)
Defrost issues (Refrigerator & Freezer Repair)
by wzard841 5/14/2011 4:13:39 PM(UTC)
by stem300 1/18/2011 1:39:02 PM(UTC)
troubleshooting defrost issues (Refrigerator & Freezer Repair)
by iccheap 7/2/2010 11:43:11 AM(UTC)
by wzard841 6/14/2010 6:03:18 AM(UTC)
GE Refrigerator Defrost Issues (Refrigerator & Freezer Repair)
by bhavinjo 5/3/2010 6:01:34 PM(UTC)
Defrost issues with electronoc control (Refrigerator & Freezer Repair)
by dw85075 3/31/2010 6:06:54 PM(UTC)
more defrost issues (Refrigerator & Freezer Repair)
by davidp 1/14/2010 6:54:47 PM(UTC)
GE side by side defrost issues, I looked (Refrigerator & Freezer Repair)
by Hankster 2/3/2008 5:36:29 AM(UTC)
