Tiny
#1 Posted : Thursday, September 22, 2011 8:27:31 AM(UTC)
Tiny
:confused: The top left burner does not come on. How do I lift the top on my glass top stove to check the element.
#2 Posted : Friday, September 23, 2011 7:15:43 AM(UTC)
This should help
http://appliancedigest.c...ing-range-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
platypus52
#3 Posted : Monday, September 26, 2011 9:33:33 AM(UTC)
platypus52
ON GLASS TOP UNITS THEY DO NOT HAVE A TRADITONAL ELEMENT. THE ELEMENT IS SEALED IN AN INSULATED ROUND COVER. IF YOU REMOVE IT BE PREPAIRED FOR SOME OF THE INSULATION TO CRUMBLE.
YOU CAN CHECK FOR CONTINUITY WITH AN OHM METER AT THE CONNECTOR WITHOUT TAKING THE BURNER ASSEMBLY LOOSE. MAKE SURE YOU HAVE TURNED THE POWER OFF AT THE BREAKER.
samsung electric burner not working (Oven Repair (including Ranges and Cooktops))
by ag0240 8/21/2022 1:58:31 PM(UTC)
Frigidaire range burner not working (Oven Repair (including Ranges and Cooktops))
by Hatt65 12/6/2020 11:35:18 AM(UTC)
Thermador x-lo burner not working (Oven Repair (including Ranges and Cooktops))
by burright 12/30/2014 4:45:01 PM(UTC)
Inner ring of 3 ring burner not working. (Oven Repair (including Ranges and Cooktops))
by William Johnson 3/17/2014 3:58:56 PM(UTC)
Kenmore gas range bottom burner not working (Oven Repair (including Ranges and Cooktops))
by scott mcgourley 10/29/2013 9:09:28 AM(UTC)
Left Front burner not working (Oven Repair (including Ranges and Cooktops))
by tyee3 2/18/2013 2:19:47 PM(UTC)
GE Spectra Profile - Large Burner not working properly - even after replacement (Oven Repair (including Ranges and Cooktops))
by friarpat 12/14/2012 9:15:17 PM(UTC)
Burner ON light stays lit but burner not working (Oven Repair (including Ranges and Cooktops))
by mkc5869 4/19/2012 6:03:56 AM(UTC)
top right burner not working (Oven Repair (including Ranges and Cooktops))
by erakowsky 4/9/2012 5:28:22 AM(UTC)
Range top burner not working (Oven Repair (including Ranges and Cooktops))
by Rolands 3/29/2012 7:25:32 PM(UTC)
Kitchenaid RR burner not working (Oven Repair (including Ranges and Cooktops))
by curtball 3/16/2012 8:32:38 AM(UTC)
Kenmore elite burner not working (Oven Repair (including Ranges and Cooktops))
by Keaka 2/27/2012 2:46:20 PM(UTC)
Jenn Air Burner Not Working (Oven Repair (including Ranges and Cooktops))
by whiterr 11/18/2011 5:24:59 AM(UTC)
glass top burner not working on whirlpool range (Oven Repair (including Ranges and Cooktops))
by heidishandy 10/22/2011 7:54:41 AM(UTC)
Half a burner not working (Oven Repair (including Ranges and Cooktops))
by thompson.5 6/28/2011 11:33:53 AM(UTC)
