Apache6434
#1 Posted : 17 years ago
Apache6434
it washes and drains but it will not spin
#2 Posted : 17 years ago
Does it agitate?
I need you to post more specific description of the problem.
abbie
#3 Posted : 17 years ago
abbie
it is most likely the drive coupling this is located under the washer it lies between the motor and the gear case.It,s not an expensive part [20] dollars or less.
Apache6434
#4 Posted : 17 years ago
Apache6434
Yes it agitates and drains and makes a humming noise when it goes into the spin cycle. I can turn the inside drum but it still will not spin
#5 Posted : 17 years ago
Pull off washer by removing panel screws and retainer clips. Short the lid switch and run washer in spin.Look above transmission to see if the clutch housing is turning, if so, you have a bad clutch, if not you have a stripped nylon gear in the tranny. Post results.
Spin cycle will not work all of the time (Washer Repair)
by Ronald Foster 14 years ago
Spin Cycle Will Not Work (Washer Repair)
by CLOVATO 16 years ago
