Apache6434
#1 Posted : Tuesday, November 27, 2007 3:22:57 AM(UTC)
Apache6434
it washes and drains but it will not spin
#2 Posted : Tuesday, November 27, 2007 3:24:44 PM(UTC)
Does it agitate?
I need you to post more specific description of the problem.
abbie
#3 Posted : Tuesday, November 27, 2007 4:08:13 PM(UTC)
abbie
it is most likely the drive coupling this is located under the washer it lies between the motor and the gear case.It,s not an expensive part [20] dollars or less.
Apache6434
#4 Posted : Wednesday, November 28, 2007 2:25:48 AM(UTC)
Apache6434
Yes it agitates and drains and makes a humming noise when it goes into the spin cycle. I can turn the inside drum but it still will not spin
#5 Posted : Wednesday, November 28, 2007 2:55:51 AM(UTC)
Pull off washer by removing panel screws and retainer clips. Short the lid switch and run washer in spin.Look above transmission to see if the clutch housing is turning, if so, you have a bad clutch, if not you have a stripped nylon gear in the tranny. Post results.
Spin cycle will not work all of the time (Washer Repair)
by Ronald Foster 8/30/2010 8:26:38 AM(UTC)
Spin Cycle Will Not Work (Washer Repair)
by CLOVATO 5/3/2009 3:09:10 PM(UTC)
