We just repaired the freezer in our GE side-by-side, but now the ice maker won't work. The defrost heater was just replaced and is working perfectly.
Hoping it's something simple that was turned off, bumped or otherwise disabled during the repair. The water is working just fine and coming through the dispenser, but it won't make ice.
Any help is appreciated.
Does the ice maker have a green status LED next to the "on-off" switch? If it does then does it stay "on" or it's blinking?
It is staying "on" and not blinking. Originally Posted by: Gene  Does the ice maker have a green status LED next to the "on-off" switch? If it does then does it stay "on" or it's blinking?
Check the water feeding tube into the ice maker for any ice build up.
