ROYEVELYN
#1 Posted : Saturday, August 20, 2011 6:01:45 PM(UTC)
ROYEVELYN
Washer won't stop spinning and draining, can't set dial to a differt cycle.:confused:
sidfink43
#2 Posted : Sunday, August 21, 2011 3:49:11 PM(UTC)
sidfink43
I cannot get your model number to come up, so am not sure what model you have.
Sounds like a control unit problem, so I would change it out to see if that fixes things.
If you need more info check your model number and post a corrected one if the one you posted is not correct.
Whirlpool washer needs help (Washer Repair)
by oconnbs 12/4/2012 4:15:24 PM(UTC)
by stephenh1 1/5/2010 11:50:31 AM(UTC)
Rusty washer needs help! (Washer Repair)
by William56 10/27/2009 10:01:58 AM(UTC)
Washer Needs help spinning (Washer Repair)
by graphixgrrl 6/9/2009 7:39:19 AM(UTC)
Roper washer Needs Help (Washer Repair)
by shane k 7/16/2008 3:52:28 PM(UTC)
Washer needs help to start spin cycle? (Washer Repair)
by randyperry 1/27/2008 11:47:22 AM(UTC)
