Washer won't stop spinning and draining, can't set dial to a differt cycle.:confused:
I cannot get your model number to come up, so am not sure what model you have.
Sounds like a control unit problem, so I would change it out to see if that fixes things.
If you need more info check your model number and post a corrected one if the one you posted is not correct.
