bestman
#1 Posted : Thursday, April 2, 2009 7:21:47 AM(UTC)
bestman
Hello All, first time here, I tested the door switch and the start switch and both are good, but the dryer will not start...anything else I should look at before the motor? Thanks
magician59
#2 Posted : Thursday, April 2, 2009 2:02:08 PM(UTC)
magician59
Check the power at the outlet. If it's an electric dryer, you should find 220-240VAC between the two hot terminals in the receptacle. If not, go the the (doubled) breaker and flip it off and back on a couple times and see if that did the job. Sometimes one of the two breakers trips and you'll get power to the door/light, but no start.
If the outlet is ok, check the fuses inside the dryer. Unplug the appliance first, before sticking your hands inside the cabinet. The electric shock is painful enough; pulling back a partial hand from the sharp edges can tend to ruin one's day.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
