hi the water come down the drain line into pan and the pan do not have heating element, water run all over my floor,does it mean the heating element is bad on the top part of the freezer . thanks
the temperature in both are normal the compressor and fan are running it just when freezer is in defost mode the water will come down on drain hose in to bottom pan where the fan is. i thought the defost heater is on top of the freezer. Originally Posted by: Gene
The size of the drip pan is good enough to hold such amount of water. Make sure the drain hose on the back of the fridge is not dislodged and the drip pan is not cracked.
Gene. P.S. There is no heaters in or around the drip pan. Water evaporates because of the hot compressor.
