G. Wedlake
#1 Posted : Monday, March 30, 2009 9:26:46 AM(UTC)
G. Wedlake
The door on our electric range does not close properly and I suspect the hinge has a broken spring on one side. Problem is: how do I get at this to see what is actually broken? It looks like I need to tear the whole side off the appliance to get at it. Is there an easy way?
Thanks for your help, Jerry W.
#2 Posted : Monday, March 30, 2009 4:14:54 PM(UTC)
Jerry,
Open the door half way and pull it up to remove it from the hinges. Each hinge (#15 on the diagram) is secured with the two screws which you can see on the part picture. Remove these screws and pull the hinge through the slot in the frame.
- The part number for the door hinge (they are identical) is AP4252510
Here are the break down diagrams and Replacement parts for AMANA ESF33002L | AppliancePartsPros.com
Oven door problem (Oven Repair (including Ranges and Cooktops))
by TugCap 4/23/2016 12:48:34 PM(UTC)
Magic Chef Oven Door Problem (Oven Repair (including Ranges and Cooktops))
by chefkingoven 8/21/2012 5:48:14 PM(UTC)
by Hermans182 12/22/2010 8:37:31 AM(UTC)
The Dreaded Oven Door Problem! (Dishwasher Repair)
by Heymate 1/20/2009 10:16:24 PM(UTC)
Tappan Wall Oven Door Problem (Oven Repair (including Ranges and Cooktops))
by florenceshield 1/9/2009 6:35:19 PM(UTC)
by Larry Golden 11/5/2008 12:59:34 PM(UTC)
oven door problems (Oven Repair (including Ranges and Cooktops))
by chopperbobby 11/3/2008 1:34:14 PM(UTC)
oven door problem (Oven Repair (including Ranges and Cooktops))
by lee-lester 9/21/2008 8:58:00 PM(UTC)
by lee-lester 9/21/2008 6:03:28 PM(UTC)
