2 Pages12>
Heymate
#1 Posted : Tuesday, January 20, 2009 10:16:24 PM(UTC)
Heymate
Would love Part Numbers and step by step guidlines for fixing a door that won;t stay shut. I have reviewed other threads but was hopefull to get specific help for this model. Thanks in advance.
#2 Posted : Wednesday, January 21, 2009 4:49:04 AM(UTC)
Cannot find any info using the given Model Number
Perhaps this will help
http://www.applianceaid.com/elecrange.html
Check out #19
#3 Posted : Wednesday, January 21, 2009 5:52:32 PM(UTC)
Looks like you posted the end of the model number. Verify and repost it.
Heymate
#4 Posted : Sunday, January 25, 2009 9:20:17 PM(UTC)
Heymate
Sorry. The Model is Whirlpool Built In Electric Oven RBS305 PDQ10
#5 Posted : Monday, January 26, 2009 1:38:54 PM(UTC)
Most likely the problem is a bad door hinge (maybe both hinges).
Remove the door as described in the Owners manual (page 13).
Put the door on a flat surface with the door handle facing down. Remove the screws holding the inner door liner and remove the liner. Follow the break down diagram.
- The part number for the door hinge is (they are identical) AP3080711
Here are the break down diagrams for the Whirlpool oven Model RBS305PDQ10
Heymate
#6 Posted : Thursday, August 6, 2009 9:19:14 PM(UTC)
Heymate
OK Gene..after your help with my dishwasher earlier this year I am ready to order the hinges. I assume I order two. (They do not come in pairs I beleive) Another question before I order the hinges. The light used to go off if I wiggled the door shut..now it never goes off and I can't figure out where the "switch" or the sensor is in the oven. Any help here would br much appreciated. Heymate
Heymate
#7 Posted : Thursday, August 6, 2009 10:46:43 PM(UTC)
Heymate
Boot removal.doc (916kb) downloaded 121 time(s).
The manual says to insert door removal pins in a hole. I see nowhere I could put these ?? Sorry to be a dummy. :(
Whirlpool RBS305PDQ10
Heymate
#8 Posted : Thursday, August 6, 2009 11:42:31 PM(UTC)
Heymate
How%20to%20remove%20the%20washer%20cabinet[1].doc (25kb) downloaded 7 time(s).
Hopefully this works this time!
Heymate attached the following image(s):
#9 Posted : Friday, August 7, 2009 3:25:01 PM(UTC)
The light switch is a part of the door latch assembly (the pin on the left side).
UserPostedImage
#10 Posted : Friday, August 7, 2009 3:40:10 PM(UTC)
[FONT=&quot]The picture file is attached.
[/FONT]
File Attachment(s):
Hole in door hinge.doc (573kb) downloaded 8 time(s).
2 Pages12>
