Dishwasher was leaking at right lower door. Replaced full door gasket and the end blocks in the cabinet. Also ordered the gasket insert that is in the lower center of the door. However, only received one in the package although two are in my door. Is one only required or did someone stuff two in the bottom of my door? The diagram shows only one. Thank you, Bill
If it spans the gap between the gasket ends only one is required. |
THIS FORUM IS DEAD!!!!!!! |
