mdcorbell
#1 Posted : Tuesday, November 20, 2007 11:17:48 PM(UTC)
mdcorbell
My Maytag Dryer Mo# MDG5500AWW won't start. It reads 18 in the display and does not respond to anything. I took the Circuit Board out and there is a small burned area on the back upper right of the board. Does this mean the circuit board burned out? And did something else cause it or was the circuit board the cause?
hcflores
#2 Posted : Tuesday, August 25, 2009 7:07:36 PM(UTC)
hcflores
Hello,
I am having the same problem with my maytag neptune dryer (mdg5500aww). The differrence is that I do not see an error code. In place of the error code is a number indicating the time left to dry. Unfortunately, the dryer won't start, nor will it display the diagnostic codes. I am able to do a membrane check (no issues with the lights), but nothing else when I follow the tech sheet directions.
I purchased a new control board from appliancepartspros, but am having the same problem as before.
Any help would be appreciated.
Hector
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
