We woke to find that the washer had not run, did diagnostic ended up replacing control board and fuse. Still won't turn on, high temp scour flashes, run test and normal light flashes also. Don't know what's up.
Here are your parts Replacement parts for WHIRLPOOL DUL300XTKT0 | AppliancePartsPros.comHere is a tech sheet https://www.servicematters.com/d...0Sheet%20-%208533399.pdfYou may have a stuck key, the tech sheet has a test procedure. Also check that the keaypad connectors are OK I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
Thanks! I will try that. Was trying to avoid a service call, but may pay more in the long run possibly.
