I bought a flame sensor from you thinking it was my problem, but the flame came on for maybe 20 seconds shut back off and wouldn't turn back on. Could you give me advise as what else it could possible be? I thought maybe it is the high limit switch in the chamber also but I put both wires together and it did nothing either.
In order to provide most accurate advise we need the complete model number of the dryer.
if the vent is clear to the outside, it is most likely the coils on the gas valve. they are cheap and easy to replace. tom
