Donhill
#1 Posted : 16 years ago
Donhill
ge gsh25kgmd frost on back of freezer , fridge warm. how do I check defrost system on this model
woodchuckie
#2 Posted : 16 years ago
woodchuckie
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.
check , defrost heater, defrost thermostat here-Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
If they are ok the problem is the control board part 801 on this diagram of your sealed system & motherboard.
Replacement parts for GE GSH25KGMDBB | AppliancePartsPros.com
#3 Posted : 16 years ago
Just to add my 2 cents...
You can check the defrost components from the main control board as described in one of our previous posts (the reply addressed to [COLOR="DarkOrange"][COLOR="Red"]bohemian[/COLOR][/COLOR]): http://forum.appliancepartspros...igerator-too-warm-3.html
