greg walter
#1 Posted : Tuesday, March 24, 2009 11:59:04 AM(UTC)
greg walter
I am getting a beeping error with an F1 Code. Oven works fine, but just beeps! Part 71003096, membrane, is no longer available. How can this part be modified to turn off the beep and the error code? Thanks!
#2 Posted : Wednesday, March 25, 2009 3:24:44 AM(UTC)
Replacement parts for JENN-AIR D156 | AppliancePartsPros.com
Here is a service manual. Note pages 4-9 to 4-12
http://www.servicematters.com/maytag_library/docs/16000446(ER001-00).pdf
Try cutting power to the unit for a couple hours perhaps it will reset.
F1 is a bad relay coil error but since your unit runs OK, it is probably a bad error code. Cannot suggest any fix to the board as the manufacturer's do not publish schematics for the boards
Check for poor solder joints of the relays on the relay board.
All I can suggest is that you check the wires from the relay board to the control board. Also clean the connectors between the relay board and control board. Use a toothbrush and either electronics contact cleaner or isopropyl alcohol. Make sure that all the solvent has evaporated before re-connecting.
Note if it still persists there are companies that will repair old/obsolete control boards but I am not 100% sure that it is a control board problem, problem could be on the relay board.
Hopefully someone else will add some help.
Jenn air oven misbehaving (Oven Repair (including Ranges and Cooktops))
by arn09 6/18/2015 11:33:24 AM(UTC)
How to remove a Jenn Air Oven Door and possible Hinge replacement (Oven Repair (including Ranges and Cooktops))
by williefan 11/6/2014 6:52:41 PM(UTC)
Jenn Air OVEN LIGHT WILL NOT SHUT OFF (Oven Repair (including Ranges and Cooktops))
by smylist 9/28/2014 7:52:50 PM(UTC)
Jenn Air oven won't heat all the way (Oven Repair (including Ranges and Cooktops))
by dmd1 1/7/2014 2:50:52 PM(UTC)
Jenn Air oven keep warm setting overheats (Oven Repair (including Ranges and Cooktops))
by scottmt 12/23/2013 1:36:40 PM(UTC)
jenn air oven (Oven Repair (including Ranges and Cooktops))
by jcvencill 1/21/2013 12:28:17 PM(UTC)
Jenn Air Oven not heating and light comes on by itself (Oven Repair (including Ranges and Cooktops))
by tdjohnson740 3/29/2012 11:57:07 AM(UTC)
Jenn air oven light won't turn off (Oven Repair (including Ranges and Cooktops))
by janna bestul 3/2/2012 12:29:25 PM(UTC)
Jenn Air oven door does not close all the way (Oven Repair (including Ranges and Cooktops))
by Meyekal 10/4/2011 8:49:54 AM(UTC)
Jenn Air oven fan noise (Oven Repair (including Ranges and Cooktops))
by IreneSN99 1/19/2011 10:41:37 AM(UTC)
Problem with Jenn Air oven (Oven Repair (including Ranges and Cooktops))
by johncher 1/17/2011 12:08:39 PM(UTC)
Jenn Air Oven Display and Controls Broken (Oven Repair (including Ranges and Cooktops))
by nittanykid 12/6/2010 4:32:42 PM(UTC)
Jenn air oven problems (Oven Repair (including Ranges and Cooktops))
by patrickC 8/17/2010 1:20:12 PM(UTC)
1970's Jenn Air Oven - Model Id (Oven Repair (including Ranges and Cooktops))
by dug320 8/7/2010 1:32:26 PM(UTC)
Jenn Air Oven (Oven Repair (including Ranges and Cooktops))
by leej 4/30/2010 8:11:47 AM(UTC)
