kcw892bc
#1 Posted : Tuesday, March 24, 2009 11:47:15 AM(UTC)
kcw892bc
Origial problem was timer would not advance and automatically shut dryer off. Replaced timer, but problem still exist. Dryer is an auto sensing unit and should advance the timer as clothes get dryer. Dryer heats properly on all tempature settings. Timer advances properly and shuts dryer off when running in timed air fluff mode.
Is solution to replace the Thermostat with part # AP4038076? Is this thermostat sensor actually a "moisture sensor"? If this is not the correct solution, can you provide the correct solution(s)?
#2 Posted : Tuesday, March 24, 2009 4:13:25 PM(UTC)
Replacement parts for MAYTAG MDE9306AYW | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16023086.pdf
See page 9-4
Not really a moisture sensor but it's normally open contacts provide power to the timer when the heater is shut off.
Looks like a good bet to me. Make sure to mark the wires before replacing it as it has normally open and normally closed contacts and an internal heater.
Only way to check it is to heat the face up with a soldering gun till it trips and then measure the normally open contacts.
Electric dryer, timer not advancing in auto mode (Dryer Repair)
by joet60 1/29/2017 7:20:59 AM(UTC)
Whirlpool Dryer Timer not advancing (Dryer Repair)
by jconkl02 5/9/2016 9:47:22 AM(UTC)
Kenmore washer timer not advancing (Washer Repair)
by sherlockbill 9/7/2015 9:37:23 PM(UTC)
by mjlj 7/6/2015 8:18:13 AM(UTC)
No heat, timer not advancing on autosense (Dryer Repair)
by fgaggia 9/5/2014 12:48:30 PM(UTC)
Maytag MDE7658BYW Timer not advancing/dryer will not shut off (Dryer Repair)
by countrybois 6/13/2014 10:47:30 AM(UTC)
Frigidare stackable timer not advancing (Washer Repair)
by aford89 3/12/2014 8:06:17 AM(UTC)
Maytag Gas Dryer Timer not Advancing = Clothes not Drying (Dryer Repair)
by troxel 3/4/2014 6:43:42 AM(UTC)
timer not advancing and no heat (Dryer Repair)
by elymoe 1/12/2014 8:44:11 AM(UTC)
Timer not advancing, but the timer is good. (Dryer Repair)
by skylux 12/17/2013 12:42:42 AM(UTC)
Roper dryer not heating and timer not advancing (Dryer Repair)
by kennethgore 12/2/2013 7:09:15 AM(UTC)
Timer not advancing (Washer Repair)
by andyvh1959 4/17/2013 7:33:49 PM(UTC)
Roper Dryer Auto timer not advancing (Dryer Repair)
by Cheryl_A 9/14/2012 7:50:11 AM(UTC)
by Ehoff 8/30/2012 11:15:28 AM(UTC)
Whirlpool dryer not heating timer not advancing (Dryer Repair)
by mbell418 7/13/2011 8:39:30 AM(UTC)
