Dave_S
#1 Posted : Saturday, March 21, 2009 7:16:38 PM(UTC)
Dave_S
The dishwasher is not getting power. We recently replaced the control board and the pump (the pump turned out to be the problem). I measured across what I think is the thermal fuse (part 6 on the control board parts diagram) and got infinite resistance. The fuse says microtemp on it, so it should be a fuse .I'm thinking the fuse is bad. Anything else I should check first? Also, the new fuse seems to come with two wires. I'm not sure what they are for. Can you tell me?
TechnicianBrian
#2 Posted : Sunday, March 22, 2009 6:29:49 AM(UTC)
TechnicianBrian
Based on your investigation, the fuse is bad and needs to be replaced. The wires that come with the fuse kit are to replace the existing connectors in the machine. There was some concern over heat being generated at the connectors contributing to the fuse failing. Once the existing connectors are removed, the wires can be stripped back and secured along with the new wires in the included terminal connector. Put some electrical tape around it to prevent and metal contact and you should be good.
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 6/3/2024 5:19:45 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest 2/18/2024 10:39:22 PM(UTC)
Gdf520pgj2ww dishwasher no power (Dishwasher Repair)
by pbajr 8/18/2023 1:00:22 PM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE JVM1540DM5WW suddenly no power a few seconds into starting it. (Microwave Repair)
by Guest 4/16/2023 11:55:25 AM(UTC)
Fridge - No power (Refrigerator & Freezer Repair)
by Guest 1/19/2023 7:36:28 PM(UTC)
Thermador t18id900lp no power (Refrigerator & Freezer Repair)
by whosurpopi 11/15/2022 9:25:21 AM(UTC)
No power to ice and water in Frigidaire FFHS2311PFEA (Refrigerator & Freezer Repair)
by Slbno1 10/12/2022 11:12:10 AM(UTC)
lg tromm dryer no power (Dryer Repair)
by Guest 8/25/2022 8:16:12 AM(UTC)
Frigidaire FGHS2631PF4A No Power (Refrigerator & Freezer Repair)
by hpreston35 8/24/2022 2:40:22 PM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
Maytag washer no power (Washer Repair)
by Guest 10/28/2021 12:07:08 PM(UTC)
