Spero
#1 Posted : Saturday, March 21, 2009 7:44:53 AM(UTC)
Spero
I have a 9 year old GE side by side fridge and temps are not keeping correct. I did vacuum the back side after taking off the cover and I can feel that the compressor is running and there is no freezing off the coils going on. I spoke with GE repair phone service and they said to vacuum the back of the fridge and there is a cylinder black plastic casing on the freezer side and it was covered in dust and I think that is a protective casing around the coils. Any thoughts or help would be helpful. Thanks.:)
#2 Posted : Sunday, March 22, 2009 1:40:38 AM(UTC)
Whats running/not running, freezer fan, condensing fan? Jam the condensing fan and check compressor, it just might not be running!
Spero
#3 Posted : Sunday, March 22, 2009 3:53:55 AM(UTC)
Spero
Plastic white fan in the back that pulls the heat from the coils is running, compressor is running too. Freezer cools to about 20 degrees and the fridge is cool on the bottom to about 40 degrees but the top seems warm. There is a cooling duct on the top section od the fridge that is not blowing any cold air out of so I am sure this is one problem. There is a fan on the freezer side that normally runs when you close the door and it is running most of the time now. I woke up this morning and did not hear it running so I am sure it will turn on when temp is too high to cools it down. For some reason the ice maker is not making ice either which may be related to the temp issue. Thanks for all your help and quick responnse.
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
Kenmore Side by Side Water Inlet Lines (Refrigerator & Freezer Repair)
by Don49 3/15/2024 12:21:35 PM(UTC)
Frigidaire FGHS2655PF5A Gallery side by side (Refrigerator & Freezer Repair)
by Rube 2/27/2024 7:56:33 PM(UTC)
GE side by side turns on only when I disconnect J4 plug (Refrigerator & Freezer Repair)
by PandaTaco 1/11/2024 10:04:34 AM(UTC)
Whirlpool Gold Side by Side (GSS26C4XXF03/HR14386344) Door Ice Maker Troubleshooting (Refrigerator & Freezer Repair)
by ForumUser1 12/25/2023 11:44:03 AM(UTC)
Whirlpool Side by Side Gold Series - circa 2010 (Refrigerator & Freezer Repair)
by ForumUser1 12/18/2023 8:29:01 AM(UTC)
whirlpool side by side freezing up periodically (Refrigerator & Freezer Repair)
by Guest 11/2/2023 6:19:56 AM(UTC)
GE Adora Side by Side Freezer won't get below 20 degrees (Refrigerator & Freezer Repair)
by Guest 10/16/2023 7:24:15 AM(UTC)
Whirlpool Side By Side Ice Maker Power Failure (Refrigerator & Freezer Repair)
by Bollweevil 9/29/2023 6:11:03 PM(UTC)
Frigidaire side by side - warm freezer cold fridge - help please (Refrigerator & Freezer Repair)
by Doug427 1/23/2023 4:36:18 PM(UTC)
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 1/8/2023 8:50:08 AM(UTC)
Crosley, model: GS24Y8DV, side by side Refrigerator/Freezer. (Refrigerator & Freezer Repair)
by AeroncaChief 11/9/2022 4:07:46 PM(UTC)
GE side by side water and ice not working (General Talk)
by Guest 10/8/2022 6:17:31 AM(UTC)
