nhoj
#1 Posted : Thursday, March 19, 2009 2:29:03 PM(UTC)
nhoj
the oven took 45 minutes to heat to 250 i can hear a switch-relay clicking on-off. i am attempting to findout part# before i tear the top off the stove:confused:
TechnicianBrian
#2 Posted : Thursday, March 19, 2009 3:51:37 PM(UTC)
TechnicianBrian
Everything is controlled by the oven control board (AP2127094), but if it is slow to preheat, you may want to verify voltage to both elements and check them both for proper resistance and that there is no visible damage. I would suspect our bake element is not working and the preheating being done is only through the cycling of the broil element.
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Jenn-air oven troubles (Oven Repair (including Ranges and Cooktops))
by SteveDB 10/8/2011 8:46:43 PM(UTC)
electric oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by prousseau 2/18/2011 6:27:10 AM(UTC)
by enzo731 5/29/2009 2:43:06 PM(UTC)
