nhoj
#1 Posted : 16 years ago
nhoj
the oven took 45 minutes to heat to 250 i can hear a switch-relay clicking on-off. i am attempting to findout part# before i tear the top off the stove:confused:
TechnicianBrian
#2 Posted : 16 years ago
TechnicianBrian
Everything is controlled by the oven control board (AP2127094), but if it is slow to preheat, you may want to verify voltage to both elements and check them both for proper resistance and that there is no visible damage. I would suspect our bake element is not working and the preheating being done is only through the cycling of the broil element.
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 12 months ago
Jenn-air oven troubles (Oven Repair (including Ranges and Cooktops))
by SteveDB 13 years ago
electric oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by prousseau 14 years ago
by enzo731 16 years ago
