water started leaking from water and ice dispenser:confused:
what may be causing this?
The dual water inlet valve on the back where the water supply come in probably has gotten sediment in it preventing it from sealing completely. You can disconnect the two lines coming out from it and see if it's leaking there. Here's pictures of it. WHIRLPOOL Valve, water, part number: 12195504
