mikeSR
#1 Posted : Monday, March 16, 2009 9:43:12 AM(UTC)
mikeSR
water started leaking from water and ice dispenser:confused:
what may be causing this?
woodchuckie
#2 Posted : Monday, March 16, 2009 10:10:18 AM(UTC)
woodchuckie
The dual water inlet valve on the back where the water supply come in probably has gotten sediment in it preventing it from sealing completely. You can disconnect the two lines coming out from it and see if it's leaking there.
Here's pictures of it. WHIRLPOOL Valve, water, part number: 12195504
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
GE Profile PSHS6PGZBESS water leaking from dispenser (Refrigerator & Freezer Repair)
by Guest 12/30/2021 5:30:45 PM(UTC)
water leaking inside (Refrigerator & Freezer Repair)
by csegel 7/21/2020 9:15:26 AM(UTC)
water leaking IN to the tub (Washer Repair)
by gabericks 7/5/2020 2:21:45 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
Kenmore - Water leaking from cracked connectors (Refrigerator & Freezer Repair)
by allengl1 8/12/2019 9:02:34 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Frigidaire - Water Leaking from Electronic Defrost Control Area????? (Trash Compactor Repair)
by BJPrice 2/1/2018 3:20:07 PM(UTC)
Water leaking from brand new LG door in door fridge (Refrigerator & Freezer Repair)
by Jason B 7/20/2017 12:58:06 PM(UTC)
Water Leaking at Water Inlet Valve (Refrigerator & Freezer Repair)
by marshmore 12/24/2015 8:00:34 AM(UTC)
water leaking? in freezer (Refrigerator & Freezer Repair)
by chknmom 10/16/2015 3:50:20 PM(UTC)
water leaking on floor (Refrigerator & Freezer Repair)
by capetish 8/23/2015 6:39:00 PM(UTC)
Ice build up bottom of the freezer and water leaking the front door unto the floor (Refrigerator & Freezer Repair)
by BEbner 5/22/2015 1:56:55 PM(UTC)
water leaking from soap dispenser housing (Washer Repair)
by suekevin 1/8/2015 12:21:56 PM(UTC)
