bottom oven of a double starts to warm up and then just turns off. sometimes a F1 code appears. upper oven works fine all the time. Are the touch pad and oven control all one part number
Most likely the problem with your oven is a bad ERC (Electronic Oven Control). - The part number for the ERC AP2025104 The control panel is a different part with different part number. - The part number for the black control panel AP2029064 - The part number for the white control panel AP2029065 Gene.
I am trying to replace my shattered door to a G.E. Double Oven, Black, Model # JKP44GOP1BG, Serial# GF6204330. Can anyone help me locate one or a replacement glass?? Help?:confused:
The part number for the black outer door glass is AP2035237 Gene.
