b015dwj
#1 Posted : Thursday, July 14, 2011 5:28:02 AM(UTC)
b015dwj
Cutting ice grid is not cutting the ice. I removed and cleaned it. all wires and connections look good.
Jeff / APP Team
#2 Posted : Thursday, July 14, 2011 11:15:55 AM(UTC)
Jeff / APP Team
Hello b015dwj. You will want to test the grid cutter and make sure it is good. It should read closed for continuity. If it is good, you will need to test and see if there is power coming to the transformer and from the transformer to the grid cutter. You should have 120 VAC coming to the transformer. It is low voltage coming out and you should read between 8 to 12 VAC. If not, you will need to replace the transformer. Hope this helps.
Part number: AP3956373
Kitchenaid Ice Maker Lever Problem (General Talk)
by Guest 11/4/2021 10:00:56 PM(UTC)
Kitchenaid ice maker help (Refrigerator & Freezer Repair)
by Fridge276 7/31/2020 3:09:46 AM(UTC)
KitchenAid Ice Maker won't stop turning. (Refrigerator & Freezer Repair)
by slipsibm 5/30/2020 10:15:54 AM(UTC)
KitchenAid ice maker - ice sometimes slides into reservoir pan rather than onto cutter grid (Refrigerator & Freezer Repair)
by thall88 12/7/2018 1:59:31 PM(UTC)
KitchenAid ice maker not dispensing ice (Refrigerator & Freezer Repair)
by kkranzo 7/6/2017 7:19:23 PM(UTC)
Kitchenaid Ice Maker Issue (Refrigerator & Freezer Repair)
by phillyphan 5/29/2017 1:06:55 PM(UTC)
KitchenAId Ice Maker not working (Refrigerator & Freezer Repair)
by mmciel 12/21/2012 8:28:40 PM(UTC)
KitchenAid ice maker not working (Refrigerator & Freezer Repair)
by lizprimary 12/15/2012 2:42:41 PM(UTC)
Icicle forming underneath KitchenAid ice maker (Refrigerator & Freezer Repair)
by AaronGo 10/15/2012 5:28:19 PM(UTC)
by East Texas 4/25/2012 11:06:10 AM(UTC)
KitchenAid Ice Maker Not Getting Water (Refrigerator & Freezer Repair)
by Steingraber 3/4/2012 12:49:54 PM(UTC)
kitchenaid ice maker not working (Refrigerator & Freezer Repair)
by laurn 12/19/2011 6:44:32 PM(UTC)
Dripping KitchenAid Ice Maker (Refrigerator & Freezer Repair)
by tonymarch 9/8/2011 5:16:52 AM(UTC)
kitchenaid ice maker (Refrigerator & Freezer Repair)
by hommebr 4/29/2011 12:33:56 PM(UTC)
Kitchenaid Ice Maker (Refrigerator & Freezer Repair)
by pistilli777 10/26/2010 11:51:01 AM(UTC)
