ASTRO1954
#1 Posted : Saturday, March 14, 2009 5:55:37 PM(UTC)
ASTRO1954
Dryer Won't Start, Only Makes Loud Humming Noise
#2 Posted : Saturday, March 14, 2009 7:07:56 PM(UTC)
Either the motor bearings seezed, or something got stuck in the blower housing. Remove front panel and check.
ASTRO1954
#3 Posted : Saturday, March 14, 2009 10:52:32 PM(UTC)
ASTRO1954
I Don't Have Operators Manual On Ge Dryer Model# Dx4500e0ww .
How Do I Get To The Drive Motor ? From The Back Or Front? I Have Removed All The Screw From The Back Panel. Am I Missing Something? Thanks In Advance
#4 Posted : Sunday, March 15, 2009 3:31:52 AM(UTC)
There are some screws in the front under the door to remove, either phillips or torq. Remove these, lift the top up, and remove the screws holding the front panel in place. You can stick your arms under the drum and remove the belt, then lift out the drum.
ASTRO1954
#5 Posted : Sunday, March 15, 2009 10:45:29 AM(UTC)
ASTRO1954
Thanks! If I Can Make This Repair (with Your Help) Maybe I've Found A New Career! With The Economy The One I Now Have Is Pretty Weak. Thanks, Guys , For Your Help;)
LG dryer makes humming sound for a few seconds when start button is pushed (Dryer Repair)
by vertspd 11/3/2016 10:36:25 AM(UTC)
Whirlpool Dryer makes humming sound (Dryer Repair)
by grice98 3/23/2009 1:20:09 PM(UTC)
Dryer makes humming sound when turning cycle selector (Dryer Repair)
by skull 1/17/2009 10:39:19 AM(UTC)
