There is a loose white plug inside the back of fridge. It is on the bottom at the lower left side right inside the frame. I can't find where it plugs into. Any ideas?
There is a fan that blows on the coils under there that could have a plug. Is it running. Are you having any problem with the unit.
Originally Posted by: woodchuckie  There is a fan that blows on the coils under there that could have a plug. Is it running. Are you having any problem with the unit. The line is just there and I can't see where it would hook into. The fan is running.
Originally Posted by: DJ Price  The line is just there and I can't see where it would hook into. The fan is running. Other than no water/no ice it is working fine.
