Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Came back to cottage after unusual hotspell to find smell of hot fridge. Pulled away from walland found condenser fan turning very slowly (2 rpm). Unplugged and ordered new condenser fan Supco 5109. Installed fan. Had fridge on a gfci'd plug and it tripped it as soon as plugged in. Verified wiring with same result. Plugged into a normal 15a receptacle and it both condenser and fan started. Ran for 5 minutes then quit (was nowhere near set temperature). Am I missing something?
