firedude
#1 Posted : Wednesday, July 6, 2011 4:47:50 PM(UTC)
firedude
kemore series 70 heavy duty: when in the delicate cycle it will fill and agitate but does not drain or spin. So for the other cycles are not affected. Is this possibly a timer problem, if so how do I test the timer for a specific cycle?
sidfink43
#2 Posted : Friday, July 8, 2011 3:48:55 PM(UTC)
sidfink43
It is very likely a timer problem. You can try disconnecting the timer and cleaning the contacts with a good contact cleaner, but in the end I think you will just have to replace the timer.
Guest
#3 Posted : Saturday, October 23, 2021 7:00:28 AM(UTC)
Guest
Rank: Guest
United States
My Kenmore heavy duty70 series washer starts spinning get almost up to speed makes a little grinding noise n then makes a loud bang and slows slightly then speeds back up n bangs again. If I hold the agitator still while it spins theirs no bang runs like normal. What might be going out or is wrong
Kenmore 70 series (11066712694) cycling thermostat wire damage (Dryer Repair)
by cyberdingo 3/6/2024 6:26:19 PM(UTC)
Sears Kenmore 70 Series . Model 110-82870120 (Washer Repair)
by washerTed 10/2/2023 6:42:28 AM(UTC)
Kenmore 70 series not starting after breaker tripping (Dryer Repair)
by thenameskilo 4/7/2021 10:25:38 PM(UTC)
Kenmore 70 series not starting (Dryer Repair)
by thenameskilo 4/7/2021 10:24:08 PM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
kenmore 70 series problem (Washer Repair)
by richham 6/13/2015 4:08:08 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Kenmore 70 series washer doesn't work (Washer Repair)
by kman6206 1/17/2015 3:38:49 AM(UTC)
Kenmore 70 series (Washer Repair)
by D.mccauslin 1/7/2015 6:20:04 PM(UTC)
kenmore 70 series not spinning unless manually put to spin (Washer Repair)
by adm388 8/13/2014 8:58:14 PM(UTC)
Kenmore 70 Series Dryer Heating Element (Dryer Repair)
by VSimon10 3/6/2014 2:19:25 PM(UTC)
Kenmore 70 series agitates but no longer spins (Washer Repair)
by ken110 1/26/2014 5:19:15 AM(UTC)
Kenmore 70 series washer agitates but does not spin (Washer Repair)
by tismichael 11/16/2013 2:02:16 PM(UTC)
Kenmore 70 series washer won't drain or spin (Washer Repair)
by ImSR 10/12/2013 8:49:49 AM(UTC)
Kenmore 70 Series Electric Dryer Won't Start (Dryer Repair)
Belarus rdtraverse 12/26/2012 6:31:15 PM(UTC)
