D.mccauslin
#1 Posted : Wednesday, January 7, 2015 6:20:04 PM(UTC)
D.mccauslin
Ok guys and gals I have a Kenmore 70 series washer that does not spin, it does drain and sounds like motor is running. I can get it to spin if I push in the control knob and then pull out, it wil run fine until the next spin cycle and then I have to do the same thing.
fairbank56
#2 Posted : Thursday, January 8, 2015 7:09:52 AM(UTC)
fairbank56
Groups: Expert
It is supposed to drain for a full 2 minutes without spinning, regardless of how long it actually takes to drain. After the 2 minutes, the motor should stop and then start again. This shifts the transmission out of neutral and then it should start spinning while continuing to drain. If there is no pause of the motor after the 2 minute drain period, the timer is faulty. You are pausing the motor when you push the knob in and out again. If the motor does pause properly but still won't spin unless you cycle the power again, there is likely a problem with the transmission.
Eric
Kenmore 70 series not starting after breaker tripping (Dryer Repair)
by thenameskilo 4/7/2021 10:25:38 PM(UTC)
Kenmore 70 series not starting (Dryer Repair)
by thenameskilo 4/7/2021 10:24:08 PM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
kenmore 70 series problem (Washer Repair)
by richham 6/13/2015 4:08:08 PM(UTC)
Kenmore 70 Series washer not spinning (Washer Repair)
by workingdad 2/21/2015 7:31:47 PM(UTC)
Kenmore 70 series washer doesn't work (Washer Repair)
by kman6206 1/17/2015 3:38:49 AM(UTC)
kenmore 70 series not spinning unless manually put to spin (Washer Repair)
by adm388 8/13/2014 8:58:14 PM(UTC)
Kenmore 70 Series Dryer Heating Element (Dryer Repair)
by VSimon10 3/6/2014 2:19:25 PM(UTC)
Kenmore 70 series agitates but no longer spins (Washer Repair)
by ken110 1/26/2014 5:19:15 AM(UTC)
Kenmore 70 series washer agitates but does not spin (Washer Repair)
by tismichael 11/16/2013 2:02:16 PM(UTC)
Kenmore 70 series washer won't drain or spin (Washer Repair)
by ImSR 10/12/2013 8:49:49 AM(UTC)
Kenmore 70 Series Electric Dryer Won't Start (Dryer Repair)
by rdtraverse 12/26/2012 6:31:15 PM(UTC)
wont stop ,,kenmore 70 series (Dryer Repair)
by michael chesser 12/7/2012 7:40:53 PM(UTC)
Kenmore 70 series gas dryer (Dryer Repair)
by DenieJon 10/8/2012 8:37:46 AM(UTC)
Kenmore 70 Series Pigtail Change (Dryer Repair)
by Laurelc43 8/16/2012 4:54:17 PM(UTC)
