mlevine
#1 Posted : Wednesday, July 6, 2011 12:59:14 PM(UTC)
mlevine
this is an expensive unit. retail 500-600. sounds like all is running but unit does not heat up. doesn't look like the door sensor.
Can you trouble shoot! Is it worth fixing $100 labor plus parts???
#2 Posted : Wednesday, July 6, 2011 3:45:58 PM(UTC)
What does it do after you push the start pad? Lights, sounds, turntable etc?
Do you fill comfortable to fix it yourself?
Here are the breakdown diagrams and Replacement parts for General Electric JVM3670BF02 Counter top microwave | AppliancePartsPros.com
mlevine
#3 Posted : Wednesday, July 6, 2011 5:02:10 PM(UTC)
mlevine
everything works ecept for the heat.
can't fix myself.
mlevine
#4 Posted : Wednesday, July 6, 2011 5:05:40 PM(UTC)
mlevine
cannot fix myself. all bells and whistles seem to be working except for heat
#5 Posted : Thursday, July 7, 2011 2:58:46 PM(UTC)
Possible the problem is a bad magnetron. If the microwave is less then five years old then the part is still under the warrant and you pay for labor only.
If it's not under the warranty, then the part you can order from APP for $156.01 and pay someone to replace it.
- The magnetron Part number: AP2025937
20 yr old kenmore washer Is it worth fixing (Washer Repair)
by rjl75 1/15/2014 9:14:49 AM(UTC)
Is It worth fixing (Washer Repair)
by buster40404 8/27/2011 2:40:14 PM(UTC)
Kenmore Model 23832100 Is it worth fixing? (Washer Repair)
by JosephAllenCavin 1/2/2009 12:53:12 PM(UTC)
