my dryer runs fine except the heat quit. i have changed the element & thehigh limit thermostat.i would like a few test procedures to find the source of the problem.
Check the heater relay (#5 on the diagram). The resistance reading of the coil portion of the relay should be about 490 Ohms. - The heater relay Part number: AP4037260
Is that the wire that runs from the relay to the heating coil?
