slowey
#1 Posted : Thursday, June 30, 2011 11:47:52 AM(UTC)
slowey
my dryer runs fine except the heat quit. i have changed the element & thehigh limit thermostat.i would like a few test procedures to find the source of the problem.
#2 Posted : Thursday, June 30, 2011 2:31:41 PM(UTC)
Check the heater relay (#5 on the diagram). The resistance reading of the coil portion of the relay should be about 490 Ohms.
- The heater relay Part number: AP4037260
danlajoie
#3 Posted : Tuesday, July 3, 2012 3:00:12 PM(UTC)
danlajoie
Is that the wire that runs from the relay to the heating coil?
Dryer has no heat. (Dryer Repair)
by Goatman48 2/12/2018 3:16:53 PM(UTC)
my roper dryer has no heat (Dryer Repair)
by vanj333 8/8/2012 3:11:18 PM(UTC)
Dryer has NO heat, but runs (Dryer Repair)
by MCH_STL 7/12/2012 3:20:18 PM(UTC)
maytag dryer HAS NO HEAT! (Dryer Repair)
by gtopij 5/1/2012 2:13:30 PM(UTC)
Frigidaire Dryer Has No Heat (Dryer Repair)
by moody9207 4/22/2012 6:18:15 PM(UTC)
electric dryer has no heat (Dryer Repair)
by Anthony Cetani 1/22/2012 5:52:08 AM(UTC)
Dryer has no heat (Dryer Repair)
by marcustheman 10/17/2011 7:22:16 AM(UTC)
by Ken Louie 9/27/2011 3:50:23 PM(UTC)
Frigidare Dryer has no heat and timer does not work (Dryer Repair)
by qt3110 9/19/2011 9:05:10 PM(UTC)
dryer has no heat & wont run (Dryer Repair)
by K Graber 4/5/2011 10:34:19 AM(UTC)
by tbtpounce 3/24/2011 10:42:14 AM(UTC)
Gas Dryer has no heat (Dryer Repair)
by bmpaul 8/11/2010 2:48:42 PM(UTC)
by slim10 4/8/2010 8:10:12 AM(UTC)
HELP!!! Dryer has no heat (Dryer Repair)
by quinn9829 11/12/2009 6:44:51 AM(UTC)
by tlpyle 7/16/2009 6:33:20 PM(UTC)
