My fridge is not that cold A 3 on a (1-10) and my freezer is cold but not mucha 5 on (1-10). Also there is water drips on the bottom of the freezer door outside and top of fridge door outside on top
Need more info, fans, compressor running. Also, measure the freezer and fridg. temperatures.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Need more info, fans, compressor running. Also, measure the freezer and fridg. temperatures. fans are running also compressor fridge temp 44 F freezer 5 F
all is running fridge 44 f frezzer 5 F
Clean the condenser fan blade and condenser coils. If it still is running constantly probably a refrigerant leak or worn compressor. A compressor running constantly will waste about $100 per month.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Clean the condenser fan blade and condenser coils. If it still is running constantly probably a refrigerant leak or worn compressor. A compressor running constantly will waste about $100 per month. i cleaned the fan and coils and it is still running the also the freezer fan is too It is less noisy though now what do i do. How do you know if there is a refrigerant leak,(could it be a stuck defrost timmer)?
You might just have bad door gaskets. If a dollar bill is pushed between the door frame and the gasket and it can be pulled out easily, you have bad gaskets and/or a broken one under the fridg door. If bad, sometimes you can smear vaseline on them, duck tape them shut overnight and see if that helps.
